Bulhead
May 18, 2020Tutor
Smart TVs won't connect to internet
Hi I have just installed an Orbi Mesh network with RBK50s. Everything is working brilliantly and really fast apart from my 2 Smart TVs - a Panasonic and a Samsung. Both connect to the router, but not...
Bulhead
May 18, 2020Tutor
It's a Sagemcom Plunet One Hub
May 18, 2020Guru - Experienced User
Bulhead wrote:It's a Sagemcom Plunet One Hub
Thats a modem router combo device. putting you in a double nat
https://kb.netgear.com/30186/What-is-Double-NAT
you can try placing it in passthrough/modem only mode (contact isp for help with that) or try placing your orbi in Access point mode.
- BulheadMay 18, 2020Tutor
Hi, so spoken to ISP and switching pass through or bridge mode is not something they support on.
I can access my advanced settings and disable the wifi (2.4 and 5ghz) which I thought be equivalent to passthrough mode. I have done this and it did not help.
I am also finding some websites are blocked (interestingly one being the link on the page you sent which links to How to fix Double NAT issues!)
would purchasing my own modem solve the problem?
- plemansMay 18, 2020Guru - Experienced User
Bulhead wrote:Hi, so spoken to ISP and switching pass through or bridge mode is not something they support on.
disabling wifi doesn't fix the issue. it still leaves 2 routers running in router mode on the network.
Try putting the netgear in access point mode.
Thanks for taking the time to respond to me. I had trouble getting into the orbilogin so phoned Netgear support. As I logged in it came up with a note to say that the router was moved to another 'channel' I think. The when I logged in again the issue was resolved without me having to go into access mode.
Have to say the support was really good.
Thanks again
