Superpop
Feb 06, 2017Star
So if I was to return the Orbi
Wanting to try an alternate to the Orbi to see if I can get any better performance out of a stand alone wifi router before returning the Orbi to Costco. What is the best consumer grade router that I...
Superpop
Feb 07, 2017Star
I guess I was not clear, is there a router out there that will cover a 4000SF stick built house without repeaters or AP's
st_shaw
Feb 07, 2017Master
Superpop wrote:I guess I was not clear, is there a router out there that will cover a 4000SF stick built house without repeaters or AP's
Definitely not using 5 GHz. You might be able to get OK coverage using 2.4 GHz, but it won't be fast far from the router.
Given that you have wired infrastructure, your best bet would be wired APs, like the Ubiquiti Unifi APs.
Repeaters are a poor solution, but It's not clear why you don't want to go the AP route.
