PaoloGhiara
Jul 20, 2020Tutor
Social Networks not updating
For some time, perhaps after a switch to firmware 2.5.1.16, social networks no longer update or do so once in a while (like every half an hour, or more). It happens with any mobile phone connected t...
- Jul 23, 2020
Ok. Glad you got it working.
25feet maybe too close. 30 feet or more is recommended. You may want to turn down the power output of the RBR from 100% to 74 or 50%. Under Advanced Tab/Advanced Settings/Wireless Settings
Mark your thread as solved so others will know.
Enjoy. :smileywink:
Jul 21, 2020Guru - Experienced User
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6. Save settings and reboot the router and satellite(s).
PaoloGhiara
Jul 22, 2020Tutor
I followed all you suggestions and it seems to work!
The chat applications update now in real time. At least in the last 20 hours.
Bt the way the Orbi is directly connected to the provider (no additional rmodems), it's in an area of less than 300sqft and the satellite is about 25ft far.
Thank you
- FURRYe38Jul 23, 2020Guru - Experienced User
Enjoy. :smileywink:
