thuynhj
Jul 28, 2021Aspirant
Software-based Firewall necessary?
Hi I have an Orbi RBR50 and I know there is a built in firewall. Are you using a software-based firewall in addition to the one that is built in from the router? If so, which one and which AV softw...
Jul 28, 2021Guru - Experienced User
Shouln't be necessary. I don't use external FW accept the ones built in to Windows platforms.
