RedBatman89
Oct 11, 2019Guide
Software bug discovered for rbr20 and rbs20 (rbk23) units on 2.3.5.26
Okay so this is long so I will first provide links to my findings https://community.netgear.com/t5/Orbi/Odd-Ping-bug-I-have-discovered/m-p/1804890#M71368 https://community.netgear.com/t5/Orb...
RedBatman89
Oct 12, 2019Guide
Edit: Apparently wired seems to be okay. I just connected my laptop to the router via ethernet and when I pinged the two other sattleite I didnt get any destanation host unreachable error. So it seems to happen only with you are wirelessy connected to the router and then try to ping the sattleites that gives the issue. Again this is bad for people who do a lot of data sharing. Internet works on all units its just this issue can be problamatic.
