Jimmah82
Aug 16, 2020Aspirant
Solid Magenta daily drop out
Every morning I awake to find my Orbi router has disconnected with a solid magenta light. Unplugging/plugging back in or a reboot resolves the issue temporarily. I'm on firmware V2.5.1.16. I have...
Jimmah82
The Orbi is connected to an NBN Arris CM8200 modem. I'm on a Telstra HFC plan (Australia).
The modem does not disconnect from the internet, only the Orbi drops out each day.
It's likely a 24 hour period between restart and a lost connection. I restart it each morning, it is fine during the day and early evening but has dropped out by the next morning.
Mstrbig
Aug 16, 2020Master
Jimmah82 wrote:The Orbi is connected to an NBN Arris CM8200 modem. I'm on a Telstra HFC plan (Australia).
The CN8200 is a straight ISP modem, so there should be no issues there. Do you have any sort of scheduling going on? Maybe a power issue? Have you rebooted the modem? If it is losing connection close to the same time every day, it is more of a setting than the Orbi itself.
