tp44785
Aug 22, 2018Aspirant
Solid Purple Ring on RBR50 in AP Mode
Here's my setup -
RBR50 in AP Mode (have an existing firewall so making this a router is not an option) RBS50 Satellite (wireless backhaul) RBS40 Satellite (wireless backhaul)
All unit...
Aug 22, 2018Guru - Experienced User
You can use either LAN or WAN port. WAN is recommended by NG and if you use this port, the top LED should not be on as PINK and should turn BLUE then go OFF. Its not a bug if your not using the WAN or LAN port.
You can't disable the LED at all.
