tp44785
Aug 22, 2018Aspirant
Solid Purple Ring on RBR50 in AP Mode
Here's my setup -
RBR50 in AP Mode (have an existing firewall so making this a router is not an option) RBS50 Satellite (wireless backhaul) RBS40 Satellite (wireless backhaul)
All unit...
toe
Aug 24, 2018Apprentice
tp44785 wrote:
Here's my setup -
All units are at latest firmware - 2.1.4.16. Wireless works fine but there is always a solid purple ring on the RBR50 unit. I have read this indicates access to Internet has been lost but that's not the case (unless it is testing this on the WAN port which is not in use in AP mode, in which case this is a bug). Is there any way to turn off/disable the light when it's in AP mode?
I have reported this bug to Netgear. No response yet after 2 weeks. Not even an acknowledgement.
Aug 25, 2018Guru - Experienced User
The PINK led should go out if you use the WAN port in AP mode.
toe wrote:
tp44785 wrote:
Here's my setup -
