tp44785
Aug 22, 2018Aspirant
Solid Purple Ring on RBR50 in AP Mode
Here's my setup -
RBR50 in AP Mode (have an existing firewall so making this a router is not an option) RBS50 Satellite (wireless backhaul) RBS40 Satellite (wireless backhaul)
All unit...
vglen
Jan 22, 2019Aspirant
I just started experiencing the same issue. I also in AP mode, as I have my own firewall. Did you ver hear back from NG? My RBS50 lights up blue and goes dark like normal. I am also getting my normal speeds. Just maddenging.
- FURRYe38Jan 22, 2019Guru - Experienced User
Connecting the Orbi router thats in AP mode using it's Yellow WAN port to your firewall?
Is the firewall also DHCP or does that come from a different service or device?
Test the Orbi connected to the main host router with out the firewall attached as a quick test?
