Skrymir
Dec 06, 2016Guide
Solid White Ring, Solid Green Power LED
I just got an additional satellite to add to my existing Orbi setup. The new satellite synced up to the router and gave me a blue ring. Things seemed to be working but devices connected to the new s...
dpdurst
Dec 07, 2016Luminary
Here is a list of the ring colors and what they mean. Sounds like the Sat thinks its still powering up if its all white. Possible bad Sat maybe if its stuck in the power on state?
Router and satellite power button LEDs
Solid green. Your Orbi router and satellite are powered on.
Solid amber. Your Orbi router and satellite are rebooting.
Pulsing amber. You must reset your Orbi router and satellite to factory default settings.
Pulsing red. Your Orbi system might need attention. Contact support.
Satellite and router ring LEDs
Pulsing white. Your Orbi router and satellite are applying a configuration or updating their firmware.
OFF. Your Orbi router and satellite are working normally.
Router ring LEDs
Solid white. Your Orbi router is powering up.
Pulsing white. Your Orbi router is in factory default mode.
Pulsing magenta. Your Orbi router ring LED might pulse magenta for the following reasons: the WAN port link is down, the router is unable to get the IP address from the modem or ISP, or the router is unable to connect to the Internet.
Pulsing blue and magenta. The Internet connection is blocked because the traffic meter is configured to block Internet traffic when it reaches the limit you configured.
Satellite ring LEDs
Solid white. Your Orbi satellite is powering up.
Pulsing magenta. When your Orbi satellite's ring LED pulses magenta for the first time, it means that your satellite is attempting to connect to your Orbi router. If the ring LED pulses magenta for more than one minute, it could be for the following reasons: the satellite lost the connection to the router or the satellite is unable to get an IP address from the router.
Solid magenta. Your Orbi satellite ring is solid magenta for 10 seconds if it is unable to obtain the IP address from the router.
Solid blue. If your Orbi satellite ring is solid blue for 10 seconds, the connection between your Orbi router and satellite is good.
Solid amber. If your Orbi satellite ring is solid amber for 10 seconds, the connection between the router and satellite is fair.
- SkrymirDec 07, 2016Guide
Tried again a day later but still having the same problem. Tried starting a ticket with Netgear but their support site just returns a server error when I submit the form.
- DarrenMDec 09, 2016Sr. NETGEAR Moderator
Hello skymir
When pressing the reset button did you hold it for 10 seconds then try to connect it to the base unit? You may also want to try and factory reset the base unit as well then try to update the satellites firmware manually.
https://www.netgear.com/support/product/RBK50.aspx?cid=wmt_netgear_organic#download
DarrenM
- SkrymirDec 09, 2016Guide
Thanks Darren.
I worked with NETGEAR support to determine the satellite is faulty and setup an RMA.
