Davisro
Oct 27, 2020Tutor
Solution for ORBI RBK50 constant disconnects
Hi. I thought I'd add a solution to a problem I've been having with my Costco ORBI RBR50 wireless router with two satellites. I see so many people complaining about this problem and Ive struggled w...
- Oct 28, 2020
Good to hear. Glad that worked. I would do a backup configuration to file for safe keeping.
Mark your thread as solved so other will know.
Enjoy. :smileywink:
Davisro
Oct 28, 2020Tutor
next day...never mind. still experiencing disconnects. I was all excited. This is NOT a solution. It does improve signal strength but not stability
wimmme
Oct 28, 2020Tutor
I had this too, beginning to notice this since march when we had to work from home all the time due to CoviD-19.
I had a Cisco VPN disconnect exactly every hour ! It was driving me nuts !!!
Since i am on firmware V2.5.2.4 and disabled DoS logging in the advanced options I don't have this anymore !
- FURRYe38Oct 28, 2020Guru - Experienced User
I recommend either trying newer version of FW or reverting back to v16;
Be sure to factory reset the system and setup from scratch after the FW has been applied...
wimmme wrote:I had this too, beginning to notice this since march when we had to work from home all the time due to CoviD-19.
