Davisro
Oct 27, 2020Tutor
Solution for ORBI RBK50 constant disconnects
Hi. I thought I'd add a solution to a problem I've been having with my Costco ORBI RBR50 wireless router with two satellites. I see so many people complaining about this problem and Ive struggled w...
- Oct 28, 2020
Good to hear. Glad that worked. I would do a backup configuration to file for safe keeping.
Mark your thread as solved so other will know.
Enjoy. :smileywink:
Davisro
Oct 28, 2020Tutor
Well so far so good!!
Changes made
-2.4 was on Auto. switched to 1
-MIMO was disabled...enabling
-Preamble was on Auto. Changed to Short
Not sure which of these did it but its been 5 hours and i havent been kicked, or seen any drop-offs. I'm using the Google Chrome Internet Connection Monitor add-in to keep a log of any WIFI interruptions
Thank you Furrye38 so much!!
Oct 28, 2020Guru - Experienced User
Enjoy. :smileywink:
