lightmaster
Jun 10, 2018Tutor
Solution to fix Orbi Satellite flashing white forever/failed upgrade
TL;DR
If your satellite upgrade fails and is stuck with the white pulsing led forever, follow Netgear's instructions for a manual upgrade, but do not download their TFTP2.exe file, use this one on ...
- Aug 13, 2018When the satellite is in Recovery mode, it will not ask for a DHCP address, and instead will only use 192.168.1.1. Also, you'll have to have it connected directly to your computer. If router is set for that subnet, it'll already take 192.168.1.1, so you'll have IP conflicts and likely be unable to see the satellite with an IP scanner. You *might* be able to reassign the router's IP, but then again you could just save a lot of trouble by connecting the satellite directly to computer. Plus a direct connection has the lowest chance for a corrupted upload.
Jun 11, 2018Guru - Experienced User
You and use WIndows built in TFTP program as well. Just have to install it via Control Panel/Add Remove Programs. Add Remove Windows programs. Find the TFTP entry and check mark it. Select Add.
