lightmaster
Jun 10, 2018Tutor
Solution to fix Orbi Satellite flashing white forever/failed upgrade
TL;DR
If your satellite upgrade fails and is stuck with the white pulsing led forever, follow Netgear's instructions for a manual upgrade, but do not download their TFTP2.exe file, use this one on ...
- Aug 13, 2018When the satellite is in Recovery mode, it will not ask for a DHCP address, and instead will only use 192.168.1.1. Also, you'll have to have it connected directly to your computer. If router is set for that subnet, it'll already take 192.168.1.1, so you'll have IP conflicts and likely be unable to see the satellite with an IP scanner. You *might* be able to reassign the router's IP, but then again you could just save a lot of trouble by connecting the satellite directly to computer. Plus a direct connection has the lowest chance for a corrupted upload.
Aug 13, 2018Guru - Experienced User
Awesome. Glad it worked and thanks for posting the steps.
Enjoy.
jmslw
Jan 16, 2019Initiate
Solution worked for me too!! thanks!!
- FURRYe38Jan 17, 2019Guru - Experienced User
- suttonrFeb 12, 2019Initiate
This worked for me too so thanks all. I set my pc network addapter to 192.168.1.10 so i guess ip doesnt matter as long as the orbi red light is flashing. Gave me default gateway of 192.168.1.1. Bit of a pain really why cant they just set it possible to firmware via usb flash hold reset for 30 seconds or something easy like that ?
dont think most people would want to start using tftp although it is easy enough when you give it a go.
now got main orbi and 4 satellites working fine on all hard wired lan
Thanks again.
- FURRYe38Feb 12, 2019Guru - Experienced User
Glad you got yours working as well. Thanks for letting us know.
Enjoy. :smileywink:
Thanks again.
