williefriends's avatar
Jan 01, 2022
Solved - Orbi RBR20 Speed Drop
Had the same problem with many people here that RBR20 wifi transmission speed drops significantly even after reset to factory default setting. After many trial and error, found the culprit was changing SSID.
Last attempt I left the default SSID "ORBI72" after factory reset, and the speed was stable even after a few days. I haven't tried changing the SSID again to prove my theory as I don't wanna mess it up again.
(Picture below is speed test of the wifi transmission, NOT the LAN speed)
1 Reply
