KryptoMagus's avatar
KryptoMagus
[Solved] Case closed
Case closed because of stupid error on my end.
  • KryptoMagus's avatar
    KryptoMagus
    Aug 10, 2019
    I was having problem with port forwarding. I have tried disabling upnp and it still doesn't work. After writing all the tests I have done, I found out that I set a static IP on the device and the gateway was set to my old router IP 192.168.1.254, instead of 192.168.1.1 I set on my Orbi.
