jjk999
Nov 12, 2020Aspirant
Solved Connection Issues with Work VPN
I just want to share my experience with the Netgear community in case it helps someone else. I've been working at home like many people the past number of months and we upgraded from the standar...
CrimpOn
Nov 12, 2020Guru - Experienced User
Thanks for sharing your experience. You sort of left out how the situation was resolved.
Changed the default DHCP IP range on the Orbi?
Assigned a static IP address to the computer that uses VPN?
or....?
What range of IP addresses did the Xfinity router assign? (192.168.1.x is one of the most common ranges. There are only three "private" IP address ranges).
Would you mind sharing which VPN is being used? (Cisco, OpenVPN, other?)
I am assuming this company is not "large". (Where I used to work, we had a "Class B" IP space of 65,000 IP addresses. Smaller companies that get a single public IP address from their ISP are pretty much forced to use a public IP space behind it.)
- jjk999Nov 23, 2020Aspirant
Yes, our company is small. We use OpenVPN. I don't know which range of addresses the Xfinity router assigned, but with the Orbi I selected a range of addresses that does not overlap with the ranges used by the company network. While I don't have a static IP address assigned to my laptop, I did reserve an IP address within the Orbi settings. It seems to be working great now.
