tiztrain
Jan 15, 2019Aspirant
Some Devices Can't Get Internet Though Connected to Wi-Fi
Hi,
So all of myy devices connect to the Orbi RBK50 fine. My partners Surface Pro 3 and Google Pixel 2 connect to the Wi-Fi but can't get any internet.
On Chrome she would get the error:
dns pr...
- Jan 15, 2019
Actually the best way to adjust your DNS settings is to adjust the settings in your router so you only have to do it for one device.
This is what I used in my settings:
Primary DNS: 8.8.8.8
Secondary DNS: 8.8.8.4
Jan 15, 2019Guru - Experienced User
What FW is currently loaded?
Could be a number of reasons and no, not a bug. I would start with ISP services and device first. Modem router combos can cause problems. If the modem is just a modem only, then DNS won't be a problem.
You can configure DNS on the Orbi router to use other DNS services besides ISP DNS. I use 1.1.1.1, 4.2.2.4 and Quad 9.
Also could be ISP services are not working well.
tiztrain wrote:
Hi,
dns probe finished bad config
So I found the following site and completed step 1 and 2:
https://www.drivereasy.com/knowledge/fix-dns-probe-finished-bad-config-error/
Why do some devices need the DNS Server settings changed? This has to be a bug right?
- tiztrainJan 15, 2019Aspirant
I made sure I updated to the latest released FW. I also downloaded it manually and installed the firmware in case there was an issue with the automatic update.
By Mfr do you mean manufacturer?
- tiztrainJan 16, 2019Aspirant
The Orbi is connected to a Telstra Gateway Max C63008D-1TLAUS.
I am using it in bridge mode and have turned the WiFi off on it.
- FURRYe38Jan 16, 2019Guru - Experienced User
Are you sure it's in bridge mode? How was the modem configured for bridge mode?
This is a gateway modem and thus it has a built in router.
Similar to this one? https://www.netgear.com/support/product/C6300.aspx
One thing you can try, configure the modem back to gateway/router mode. Then configure the Orbi for AP mode. Do device get internet in this configuration?
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Chuck_MJan 16, 2019Mentor
I would double check all clients to make sure they are getting IPs and DNS from the router and not being force fed them through a hard setting in their properties.
