mrsubtraction
Mar 12, 2023Guide
Some devices not connecting to Orbi RBR50 after new cable modem install
I recently changed my cable modem and afterwards my Orbi RBR50 network is not behaving as expected. Most devices got back onto the network with no problem, but some, notably my Synology NAS, hav...
CrimpOn
Mar 12, 2023Guru - Experienced User
One key piece of information is specifics about the two cable modems:
- What brand/model was the previous cable modem?
- What brand/model is the current cable modem?
For example, if the previous cable modem was "just a modem" (no WiFi, no router functions), the the NAS could easily have opened ports to allow access from the internet. Most NAS systems include UPnP features to make port forwarding automatic.
If the current cable modem includes router functions, then it will block connections from the internet and what the NAS does with the Orbi router will not be successful.
If this is the case, resetting everything will not be productive.
- mrsubtractionMar 12, 2023Guide
Ohh actually it’s the same modem, from the cable company, but previously it had its internal wi-fi router turned ON, and when I had it reset I asked the cable company to turn the router OFF entirely. I thought that the modem had been doing NAT alongside the Orbi router, so I thought it would be best to disable that.
So in theory this should be easier for the NAS to connect to the internet, no?
- CrimpOnMar 12, 2023Guru - Experienced User
Maybe it would be a good idea to double check that the cable tech did what was asked.
i.e. Compare the IP address that the Orbi router reports on its WAN interface against the public IP address from one of those "What's my IP?" web sites:
- On the Orbi web interface http://orbilogiin.net ) the Advanced Tab home screen will show the IP address assigned to the Orbi WAN port:
- Open a web browser to (https://whatismyipaddress.com ) The IPv4 address should match the Internet Port address exactly.
Thanks for the follow-up. Yes, I just checked and the Orbi IP and the IP shown at whatismyipaddress.com are both the same. Any other ideas? Very grateful for your thoughts!
