mgalgs
Jun 07, 2021Aspirant
Some domains related to cryptocurrency mining are blocked and possibly crashing my Orbi RBK853
I've been having issues with my Orbi router blocking certain domains related to cryptocurrency mining, and possibly crashing my router. I've never been able to access getmonero.org from behind my r...
mgalgs
Curious if anyone with an Orbi system can try accessing getmonero.org as a simple test since that's so reliably "blocked" for me. If you don't want to load it in a browser a simple `curl` test is fine:
❯ curl -L getmonero.org curl: (7) Failed to connect to www.getmonero.org port 443: Connection refused
Curious to see if anyone else can reproduce this issue because some searching online for other reports has proved fruitless.
CrimpOn
Jun 07, 2021Guru - Experienced User
mgalgs wrote:Curious if anyone with an Orbi system can try accessing getmonero.org as a simple test since that's so reliably "blocked" for me. If you don't want to load it in a browser a simple `curl` test is fine:
Curl is not the sort of thing most PC users would turn to. (Yes, it is available at least on my Windows 10 machine)
Would you mind sharing what sort of system this is?
