mgalgs
Jun 07, 2021Aspirant
Some domains related to cryptocurrency mining are blocked and possibly crashing my Orbi RBK853
I've been having issues with my Orbi router blocking certain domains related to cryptocurrency mining, and possibly crashing my router. I've never been able to access getmonero.org from behind my r...
CrimpOn
Jun 07, 2021Guru - Experienced User
mgalgs wrote:Curious if anyone with an Orbi system can try accessing getmonero.org as a simple test since that's so reliably "blocked" for me. If you don't want to load it in a browser a simple `curl` test is fine:
❯ curl -L getmonero.org curl: (7) Failed to connect to www.getmonero.org port 443: Connection refused
Curl is not the sort of thing most PC users would turn to. (Yes, it is available at least on my Windows 10 machine)
Would you mind sharing what sort of system this is?
mgalgs
This is affecting every system on my network. I've reproduced it under Linux, Mac OS, iOS, Android, and Windows (yes I have an OS addiction problem, I know).
The system that I confirmed CAN access getmonero.org after plugging directly into the modem (bypassing the Orbi) is a Manjaro Linux system.
- mgalgsJun 12, 2021Aspirant
Well shoot, thanks to help from the folks on reddit this turned out to be my DNS configuration after all. I was using a pi-hole for DNS and apparently these domains have broken DNSSEC configurations. I could have sworn I tried setting my DNS to 1.1.1.1 but I guess not...
Thanks, everyone, for your input!
