Pearly_Gates
Jul 22, 2019Aspirant
Some iPhone Apps not connecting to services over Orbi Mesh
F/W: 2.3.1.60 Google Fiber Network to ISP iPhone client Orbi just purchased and AC3300 WiFi set up for the first time yesterday 7/21/19 A couple of my iPhone games will not connect to their...
Jul 22, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem or ONT the NG router is connected too?
- Pearly_GatesJul 23, 2019AspirantModem Mfr: Google
Model: “Network Box”
Not cable ISP, but Google Fiber- FURRYe38Jul 24, 2019Guru - Experienced User
There a built in router here by chance? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
