Cicada1105's avatar
Cicada1105
Follower
Apr 03, 2020
Some laptops can’t connect to Orbi
Some of our laptops cannot connect to the Orby wireless network. They used to work and now are no longer and we have no idea why. We have turned off the power disconnected the routers and tried that full reset and it still does not work. Any ideas how to fix this?
  • FURRYe38's avatar
    What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
    Were the laptops recentlly updated on there OS?
    Esure the latops wifi adapter drivers are up to date.
    Other things to try:
    https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
    https://www.youtube.com/watch?v=ePZSc7vnRlQ
  • Retired_Member's avatar
    Retired_Member
    some?
    try resetting the laptop wifi adapter.  if some are and some aren't it's probably not the Orbi
