thetrent005
Jan 24, 2019Aspirant
Sonos and Astros A50 and Orbi
I installed Orbi and 2 satellites Sept 2018.
Sonos worked great. I keep orbi firmware updated as well as sonos.
All of a sudden This month Jan / 2019 anytime I tried to play apple music ...
- Jan 24, 2019
thetrent005 wrote:
And to add - im in Router Mode - not AP mode - to confirm
This looks to me a result of double NAT. The Arris BGW210 modem that you have is a router and has to be set in bridge mode/pass through/ DMZ forwarding if you want to avoid those issues.
Here is a way how to set it in passthough mode: https://forums.att.com/t5/AT-T-Internet-Features/Help-Configuring-BGW210-In-Bridge-Mode-IP-Passthrough-for-EA9500/td-p/5265310
thetrent005
Thanks for the help - answered questions below
What FW is currently loaded? - 2.2.1.210
What model Orbi do you have? - RBR50
What is the Mfr and model# of the ISP modem the NG router is connected too? ATT Fiber - BGW210-700
Is the Orbi system operating in Router or AP mode? I believe AP mode - all wifi connections connect to my orbit - and my orbi dishes out ip addresses
How are the Sonos connected? Wired or Wireless? All Sonos is wireless - I have 2 play 1’s paired .. Play 5, another play 1 standalone and another play 1 standalone.
What is the size of your home? Sq Ft? 4000
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials. In a straight line from one to the other .. Router -> Sat around 30 ft - Sat -> next sat - 20 foot or less. I have basement - Router - First floor sat - and 2nd foot sat .. Wireless connectivity rocks - speeds are fast throughout the house - no issues with laptops, fire sticks, Ring, iPhones etc
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. Found on Basic tab/Wireless.
Im using the ORbi app on my phone and I do not see anywhere to change channels - is there a web gui I should be using instead?
Any Wifi Neighbors near by? If so, how many? Prior I apple airport and 2 x airport express - never any issues. I live in a house in the burbs .. I see my neighbors wifi show up - its secured as well - and he is probably 75 yards away - guessing -
What WPA security modes are you using? WPA2-PSk
Try disabling the following and see: - I see none of these options -
thetrent005
Ah! I found the web gui login - looking
