thetrent005
Jan 24, 2019Aspirant
Sonos and Astros A50 and Orbi
I installed Orbi and 2 satellites Sept 2018.
Sonos worked great. I keep orbi firmware updated as well as sonos.
All of a sudden This month Jan / 2019 anytime I tried to play apple music ...
- Jan 24, 2019
thetrent005 wrote:
And to add - im in Router Mode - not AP mode - to confirm
This looks to me a result of double NAT. The Arris BGW210 modem that you have is a router and has to be set in bridge mode/pass through/ DMZ forwarding if you want to avoid those issues.
Here is a way how to set it in passthough mode: https://forums.att.com/t5/AT-T-Internet-Features/Help-Configuring-BGW210-In-Bridge-Mode-IP-Passthrough-for-EA9500/td-p/5265310
thetrent005
ekhalil
Jan 24, 2019Master
- FURRYe38Jan 24, 2019Guru - Experienced User
I believe he already mentioned his Orbi system is running in AP mode already.
- thetrent005Jan 24, 2019Aspirant
I confirmed my Orbi is in Router mode - not AP sorry for the confusion -
So to follow the ATT link above - does my Orbi good in Router mode?
- ekhalilJan 24, 2019Master
Yes you can keep Orbi in Router Mode if you set the ISP router in Passthrough Mode.
