Gabbyrn
Sep 15, 2016Aspirant
SONOS Compatability with Orbi
Is Orbi compatable with the SONOS mesh network? I have an extensive SONOS system throughout my house (7000 sq ft). It works flawlessly and I have wondered why a mesh network for a LAN application ha...
dleute
Dec 14, 2016Apprentice
I recieved my eero and google wifi today. I have first impressions of each.
eero is stupid easy to install/setup. It just worked. It does take 15+ minutes to update all the devices to the latest firmware.
Once updated everytihng was fine. However, I found speed tests to be quite dissapointing as I moved around my house (50->60mbps was considered a good test result). And it just generally felt slower all around. Speed test were also highly erratic. And it's own internal speed test doesn't get anywhere near my actual internet speed (90mbps instead of 150). Laptop tests while connected to the main router also didn't get me full 150mbps+.
I unplugged eero and plugged in google wifi with relatively low expectations. Thus far, google wifi has been significantly faster. Sitting one hop away from the router, I am still getting 110mbps while streaming a movie downstairs and sonos upstairs. Setup was not quite as smooth. Had a few hiccups but it got through it. Same amount of time.
At this moment, Google Wifi is winning hands down. When you consider it is also $200 less ($100 in my case because of black friday), it's hard to argue with it. I'll be returning eero and giving google wifi to my mom for christmas. I just got 140mbps on my laptop one hope from the main router. I may be ordering a second one of these. ;)
Neither of them can compete with Orbi when it is stable. Orbi is obscenely good (Even at $200 over google wifi). If netgear wants to send me a 3 piece Orbi kit to test and help debug until the problems are resolved, I'll consider sticking with it. Otherwise, google wifi is likely where I'm going. (Or possibly back to a linksys ea9500 which worked surprisingly well once I worked around some issues)
I'll be using each of them over the next few days. Hopefully, they will just work.
--Derrek
rugby49
Dec 15, 2016Aspirant
Great the Google is working out. Yesterday I was setting up a new XBox One S. So I figured I would start hard wired into the router over ethernet. It had to load up the update initially and it was painfully slow. After about twenty minutes I disconnnected the cable from the Orbi router and let the XBox find the wireless. After that everything was fast. Installed a game which had an 8 Gb update and agin everything was fine over wireless. Installed another game and I notice again it went painfully slow. This time I could see the download speed dropped to 785Kbs - 2.5 mbs over wireless. This is in the same room as the Orbi router. So I ran a speed test through my cell phone which showed 200mbs and ran one through my computer over ethernet into the router which came out to around 170mbs. The wireless remained extremely slow so I plugged the ethernet cable back in to the XBox and speeds were now into the 70 - 90mbs. Definitely have to keep an eye on this. In answer to a previous question regarding devices hooked into the satellite. Optimum placement of the satellite did not allow for this so, no I am not hooked directly into the satellite. Prinicpal use of the system was for wireless and for the entertainment devices. So far only a couple of issues with Sonos but I do have them set up through the Sonos bridges. I had one instance yesterday where the music skipped but I could stop what I was doing to check what the cause was.
