Gabbyrn
Sep 15, 2016Aspirant
SONOS Compatability with Orbi
Is Orbi compatable with the SONOS mesh network? I have an extensive SONOS system throughout my house (7000 sq ft). It works flawlessly and I have wondered why a mesh network for a LAN application ha...
Dynamiteboy
Feb 05, 2017Tutor
Perfect thank you for your input, I will update with what happens later this week. My step-by-step looks correct then right?
Best,
Jonathan
st_shaw
Feb 05, 2017Master
Dynamiteboy wrote:Perfect thank you for your input, I will update with what happens later this week. My step-by-step looks correct then right?
Best,
Jonathan
Good luck. Yes your steps look correct. This link explains how to switch from standard to "boost" setup. Boost is what Sonos calls the mesh network setup, even though no Boost device is required.
