Gabbyrn
Sep 15, 2016Aspirant
SONOS Compatability with Orbi
Is Orbi compatable with the SONOS mesh network? I have an extensive SONOS system throughout my house (7000 sq ft). It works flawlessly and I have wondered why a mesh network for a LAN application ha...
Dynamiteboy
Feb 11, 2017Tutor
Okay I will try that as well.
I have the Orbi 2 kit.
st_shaw
Feb 11, 2017Master
Dynamiteboy wrote:Okay I will try that as well.
I just tested with 9 sonos components actively playing a high-def stream from Pandora. There was no impact on the Orbi wireless throughput.
I have two bridges and 7 speakers, both old and new generation. I also have two CR200 controllers, which use the sonosnet wireless network.
Something must be misconfigured with your system, or there is something else going on that you haven't discovered yet.
- DynamiteboyFeb 11, 2017Tutor
I agree, its hard to for me to be entirley sold that they aren't compatiable because of everyone else saying that theres is fine. This is a stock Orbi system though, no strange changes made, no strange configs. I will continue to do more testing later this week, but I can replicate the problem so consistently that something is definitely going on. I thought there may still be a loop going on, but that would cause issues on the network as a whole reagrdless of whether music was being played or not.
When you say wireless throughput you mean testing the backend on the orbi's? Or your internet speed via speedtesting site?
- st_shawFeb 12, 2017Master
OK. I did a couple more tests and found that Sonos components with 5 GHz radios can impact the Orbi backhaul speed. I find the impact inconsequential to me though.
The testing I did was on the internal network, between two Macbook Pros (MBPs), using iperf3. If you don't have iperf, I recommend you download it and use it. It's best to test inside the network anyway, because doing so removes Internet variability.
I get either 100 Mbps, 225 Mbps, 500/580 Mbps, or 940 Mbps throughput, depending on how things are connected. The only thing impacted by Sonos is the Orbi Backhaul.
Both MBPs wireless: 100 Mbps.
One wired to Sat and one wireless to Sat: 225 Mbps.
One wired to Sat and one wired to Router: ~500 Mbps or ~575 MBs depending on Sonos setup. (Pure Orbi backhaul. See details below.)
Both MBPs wired to Sat: 940 Mbps. (Pure GigE switch speeds.)
Impact of Sonos on Bachaul:
With Sonos OFF I get a backhaul throughput of ~575 Mbps.
With all Sonos components ON I get a backhaul throughput of ~500 Mbps.
With Sonos ON but all newer Sonos components that include the 5 GHz radio OFF I get ~575 Mbps again. (That includes: Play:3, Play:5 Gen2, Playbar, Sub.)
So, the Sonos 5 GHz inter-speaker link does seem to impact the Orb'si maximum backhaul throughput by about 75 Mbps. That has zero impact on how I use the network, so it's inconsequential to me. If I need faster backhaul than 500 Mbps I will run a wire.
There appears to be no way to set Orbi's backhaul channel and no way to set Sonos' 5 GHz channel, so it looks like there's nothing to optimize here.
Maybe this information will help you understand what's happening with your setup.
- dleuteFeb 12, 2017Apprentice
This is interesting. I have no 5ghz sonos devices, but this seems like a distinct possibility. However, it should only be a problem when using those devices in their surround sound modes (5.1 surround sound). Possibly with stereo pairs (don't see info on this).
If you have these, I would suggest unpairing/disabling those features and testing again. Unfortunately, there is likely not much you can do about that 5ghz interference. I'm looking for undocumented firmware changes for either that might help.
--Derrek
