Gabbyrn
Sep 16, 2016Aspirant
SONOS Compatability with Orbi
Is Orbi compatable with the SONOS mesh network? I have an extensive SONOS system throughout my house (7000 sq ft). It works flawlessly and I have wondered why a mesh network for a LAN application ha...
dleute
Feb 20, 2017Apprentice
Yes you can mix and match wired and wireless. Just remember performance on that unit will be slower than the other two.
This does sound like wifi interference to me. If so, then the same thing will likely happen on google wifi. Should be interesting to see the results.
--Derrek
--Derrek
Dynamiteboy
Feb 20, 2017Tutor
--Derrek
I agree that is should by Wi-fi interference, but for that reason I am confused, as almost all Wifi interference should be able to be mitigated by changing channels and adjusting frequencies. Using a Wifi Scanner no other networks were on the Orbi or the Sonos channels. I just have a feeling that a different Wi-fi system like google will work. I won't know why it works, but I just want it to work at this point. Orbi and Sonos are both supposed to be plug and play and have not been thus far. I should not have to do this level of troubleshooting for either product and for that reason there is still an issue that either Sonos or Orbi needs to address, just not sure what that is.
If my Wifi tops out at 120mb/s, I think with 2 wired points and a wireless one in between with the sonos bridge plugged into one of them I have hopes that this will resolve my issues with speed drops.
A couple more questions:
- Do you reccommend an Onhub as one of the mesh points? If so which point? the main one? I have heard people getting better coverage with these (Obviously a bigger unit than google wifi)
- Would you reccommend taking the bridge out of the picture completely and just wiring in a Sonos Connect amp? This will still leave the Sonosnet intact I beleive.
