Gabbyrn
Sep 15, 2016Aspirant
SONOS Compatability with Orbi
Is Orbi compatable with the SONOS mesh network? I have an extensive SONOS system throughout my house (7000 sq ft). It works flawlessly and I have wondered why a mesh network for a LAN application ha...
Dynamiteboy
Feb 19, 2017Tutor
dleute wrote:
Yes you can mix and match wired and wireless. Just remember performance on that unit will be slower than the other two.
This does sound like wifi interference to me. If so, then the same thing will likely happen on google wifi. Should be interesting to see the results.
--Derrek
I agree that is should by Wi-fi interference, but for that reason I am confused, as almost all Wifi interference should be able to be mitigated by changing channels and adjusting frequencies. Using a Wifi Scanner no other networks were on the Orbi or the Sonos channels. I just have a feeling that a different Wi-fi system like google will work. I won't know why it works, but I just want it to work at this point. Orbi and Sonos are both supposed to be plug and play and have not been thus far. I should not have to do this level of troubleshooting for either product and for that reason there is still an issue that either Sonos or Orbi needs to address, just not sure what that is.
If my Wifi tops out at 120mb/s, I think with 2 wired points and a wireless one in between with the sonos bridge plugged into one of them I have hopes that this will resolve my issues with speed drops.
A couple more questions:
- Do you reccommend an Onhub as one of the mesh points? If so which point? the main one? I have heard people getting better coverage with these (Obviously a bigger unit than google wifi)
- Would you reccommend taking the bridge out of the picture completely and just wiring in a Sonos Connect amp? This will still leave the Sonosnet intact I beleive.
dleute
Feb 19, 2017Apprentice
I would personally avoid onhub for the time being. For one thing, there are 2 of them made by different manufacturers. For another, they are not entirely google controlled. In this case, I would say simplicity is better and stick with just google wifi units unless there is an issue that onhub can solve. Technically, onhubs may have better antennae arrangements, but that should only make a difference in the most extreme cases. Well placed google wifi units should just work.
It really shouldn't matter if you use a bridge or a connect. Like, really not at all. The only reason this would matter is if one of them was dysfunctional, then the other would work better. As I have only used a connect as my wired Sonos, I really can't speak to anything else. It seems to work well for me plugged into orbi. (They are less than an inch apart).
My advice is to start simple.
Dumb question of the day: Do you live near a police station, fire station, hospital or other public service?
--Derrek
- DynamiteboyFeb 28, 2017Tutor
After quite a few hours I was able to setup Google Wifi properly.
The biggest issue with it I encountered was the fact that each node needed to be wirelessly added to the mesh before they were wired in at a much farther away point across the house. This brought a lot of confusion and is a dumb requirement for setup. Unless these things first saw the main unit wirelessly, they could not be added to the mesh properly
Now I have 2 nodes, the bedrooms and living room wired into drops in the house. An Onhub upstairs as the main unit, and then the kitchen node which is closest to the upstairs Onhub is wireless. After much tinkering they are working all as they should be, showing up correctly in the app. A lot of trial an error was required, resetting them to factory default many times as a either the wired nodes or the wireless one would not show up depending on the order I set them up.
Finally the correct order was:
- Onhub Main unit
- Wireless Kitchen Unit
- 2 Wired nodes
Sonos is only exeperiencing slight drops when playing music, even in the dead zone kitchen. Usally pulling the full 100-120mbs.
I am baffled why this is working and Orbi did not, but I guess it doesn't matter. Obiviously the wired nodes help remove interference on the backend, but I thought the interference was on the front end, because of my wired speed test to the Satelite Orbi which had no issues (backend test).
Oh well....
- MasterbertMar 01, 2017Aspirant
having significant drop outs of sonos since last FW update - see also my new thread as i assume, that its FW 1.5.0.12 related instead of an overall issue with ORBI & SONOS in gerneral
- DarrenMApr 17, 2017Sr. NETGEAR Moderator
Hello Everyone
Is anyone still having sonos issues on the latest firmware 1.8.0.6? if so let me know so we can work with you on these issues.
DarrenM
- dleuteApr 17, 2017Apprentice
I have not been using Sonos much. I had a weird failure where some things just don't connect. My orbi network just wouldn't allow any devices on for a bit. Came back on it's own.
Orbi has been pretty solid for me. When I have had issues, I haven't been able to trace them back to orbi. (Apple products have plenty of issues without outside stuff messing them up)
--Derrek
