Gabbyrn
Sep 16, 2016Aspirant
SONOS Compatability with Orbi
Is Orbi compatable with the SONOS mesh network? I have an extensive SONOS system throughout my house (7000 sq ft). It works flawlessly and I have wondered why a mesh network for a LAN application ha...
rivets
Apr 22, 2017Apprentice
Recently installed on Orbi. iPads and iPhones drop out repeatedly and drain batteries. But Sonos seemed to be working fine, however the Orbi lost the connection to the outside world and I had to reboot it to get it to reconnect and the Sonos did not reconnect apart from the one wired to the router. Since then one room disappeared from the app but kept playing, so something us not right somewhere.
st_shaw
Apr 22, 2017Master
You need to set Sonos and Orbi to use non-overlapping channels in the 2.4 GHz band. My Orbi always uses a 40 MHz channel width, so I set Orbi on channel 1 and Sonos on channel 11. Sonos channel settings are in the controller under Settings, Advanced Settings, SonosNet Channel.
