Gabbyrn
Sep 15, 2016Aspirant
SONOS Compatability with Orbi
Is Orbi compatable with the SONOS mesh network? I have an extensive SONOS system throughout my house (7000 sq ft). It works flawlessly and I have wondered why a mesh network for a LAN application ha...
Antipodeansam7
Jun 06, 2017Apprentice
Hey guys, so similar issue that I assume is related. Have latest firmware on my Orbi and satellite, everything runs great at about 180mps throughout my house. Sonos never drops out, except; whenever I play music using my surround sound setup (may also happen with tv sound but don't notice) the stereo pair drop out briefly every couple of minutes and then come back in, however playbar continues to play.
Currently I have bridge wired into my router, Orbi on channel 1 for 2.4 and sonos on 11. Previously I had one of the stereo pair plugged into satellite as they are right next to each other instead of using the bridge but this was as bad if not worse.
So any ideas what the issue may be? Would the satellite being next door to one of the stereo pair be an issue? (Haven't moved as have number of things on that shelf plugged into it).
MachineLearner
I believe Sonos recommends trying to keep some distance between wifi-connected Sonos units and the WAP to which they are connected.
