Gabbyrn
Sep 15, 2016Aspirant
SONOS Compatability with Orbi
Is Orbi compatable with the SONOS mesh network? I have an extensive SONOS system throughout my house (7000 sq ft). It works flawlessly and I have wondered why a mesh network for a LAN application ha...
Antipodeansam7
Jun 06, 2017Apprentice
Hey guys, so similar issue that I assume is related. Have latest firmware on my Orbi and satellite, everything runs great at about 180mps throughout my house. Sonos never drops out, except; whenever I play music using my surround sound setup (may also happen with tv sound but don't notice) the stereo pair drop out briefly every couple of minutes and then come back in, however playbar continues to play.
Currently I have bridge wired into my router, Orbi on channel 1 for 2.4 and sonos on 11. Previously I had one of the stereo pair plugged into satellite as they are right next to each other instead of using the bridge but this was as bad if not worse.
So any ideas what the issue may be? Would the satellite being next door to one of the stereo pair be an issue? (Haven't moved as have number of things on that shelf plugged into it).
st_shaw
Jun 06, 2017Master
Yes, it could be an issue. Sonos uses 5 GHz for stereo pairing and Orbi uses 5 GHz for the backhaul. I have seen Sonos interfere with the backhaul and have measured reduce throughput. Try moving the Satelitte farther away from the Sonos stereo pair.
- dleuteJun 06, 2017Apprentice
I can tell you that Sonos was not working well for a while with it's internal sonosnet. It would drop several times a song. I just stopped using it for a few weeks. Eventually I switched it to use the Orbi network and things got much much better. I'm not sure how a stereo pair or surround sound would interact with that.
- st_shawJun 06, 2017Master
dleute wrote:I can tell you that Sonos was not working well for a while with it's internal sonosnet. It would drop several times a song. I just stopped using it for a few weeks. Eventually I switched it to use the Orbi network and things got much much better. I'm not sure how a stereo pair or surround sound would interact with that.
I have Sonos working fine on Sonosnet (this uses the 2.4 GHz band). I have Sonos set to use channel 11 and Orbi set to use channel 1. There should be no overlap this way.
The 5 GHz band is different. There is no ability to adjust the channels used by the Orbi backhaul or the Sonos 5 GHz inter-speaker links. Despite that, things work fine for me, as long as Sonos and Orbi aren't sitting right next to each other.
I've never tried running Sonos over WiFi.
That's how it was setup. It should work better on sonosnet, but it doesn't currently. I put the system on orbi wifi and it works for hours at a time without issues.
Does stereo still use 5ghz internally even when the Sonos main network is wifi not sonosnet? I don't have two play:1's to try it.
