MrsDrVadala
Jan 14, 2019Aspirant
Sonos dropped all Music stations except Pandora
Hello! I just purchased a new Orbi WiFi system last night. Having issues with logging in to certain websites; apple.com, att.com for starters. It gives me the Log in to www.apple.com and then states ...
MrsDrVadala
Jan 22, 2019Aspirant
Thanks, I reqad somewhere that people werew questioning the other 3 satellites working when the ORBI is in AP mode, will they still work or 'daisy chain' off each other? I want to be clear on all thie before I make the changes. I need all the satellites to work as our home is 4 levels and over 6300 sf.
Jan 22, 2019Guru - Experienced User
Yes.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
- MrsDrVadalaJan 22, 2019Aspirant
We are good there, they are working properly where they are all located with perfect signal too!! Jusdt for the life of me wish I could get it all to work. Also, I have already disabled the wifi from the Arris router, so its just using the Orbi WIFI now - do you believe that this is truly an issue with them as Bianca had stated? Before I go through all the deep end stuff?
- FURRYe38Jan 22, 2019Guru - Experienced User
Just disabling the wifi on the router doesn't resolve the Double NAT condition, this can post problems with connections by apps and devices.
Does the Modem have a web page? if it does, can you see if it has a DMZ? I believe it does.
Over all, just trying to help you find a easy way of correcting this. Take the path thats easiest for you.
It sure does - I am on it now - but to be completely honest with you, I dont see anything about 'DMZ' what categry would it be listed under? Maybe I am going to need a tech out here before I jack something up!! ugh!
