len_c
Nov 14, 2018Aspirant
sonos on an orbi guest network
I have been letting my neighbor ride on my wifi for years using an Airport extreme. I have been on the primary network, and him on the guest network. We have both had Sonos3 speakers on our individua...
- Nov 15, 2018
len_c wrote:
Thanks agian, but doesn't the "and access my local network" part of that setting kind of defeat the purpose of a guest network (at least for my purposes)? Wouldn't that give "guests" access to my printer, NAS etc?
True. Usually guest clients would not need to communicate with each other and access the LAN newtwork. That's why it's an optional parameter.
For your use case, you need to allow the device on the guest network which has the Sonos app to be able to see the speaker on the guest network to be able for this function to work. Drawback would be that all devices on the guest network will then be able to see devices in your LAN.
I know that Orbi Pro has better functionality related to Guest networks that allow better control over which services that guest clients can access.
ekhalil
Nov 15, 2018Master
In the Guest network there is a setting to allow devices on the Guest network to communicate with each other, is this enabled?
I assume that both the phone that has the Sonos app and the speaker are on the Guest network, right?
len_c
Nov 15, 2018Aspirant
Thanks for the reply. Can you point me to the location of that setting? I haven't been able to find it.
- ekhalilNov 15, 2018Master
Please see above, you find it under >> Advanced >> Setup >> Guest Network
- len_cNov 15, 2018Aspirant
