JohnZxm
Jun 29, 2019Aspirant
SONOS One can't works in RBR20 with Wireless (only one RBR20,No satellite)
I have two sonos one device, It works connect to R6200 with wireless in before. As R6200 using so long time, So I buy new one ORBI RBR20 router replace r6200. After that time, My sonos can't work pro...
Jun 30, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Try this, just temporarily disable the 5Ghz SSID broadcast while you set up SONOs on 2.4Ghz. Under Advanced Tab/Advanced Settings/Wireless Settings. Once setup, re-enable the 5Ghz SSID broadcast.
JohnZxm wrote:I have two sonos one device, It works connect to R6200 with wireless in before. As R6200 using so long time, So I buy new one ORBI RBR20 router replace r6200. After that time, My sonos can't work properly. The speed often just have 1M or 2M. and often lost connect , I need to rebuild the wifi connect then can found it. SONOS support engineer no ideal. Try so long time, They can't solved this problems.They reply me t is ORBI wireless network issue.
I using cable direct connect no problems. Did anyone have the same problems? Netgear support ,could you tell me how to solved this issue.
I also try seperate the 2.4G and 5G SSID, But not success.
JohnZxm
Jul 01, 2019Aspirant
Thanks for your reply.
I only one RBR20, Not have satellite.
SONOS one nearly RBR20,
2.4G channel has assign to channel 01.
Already enabling Beamforming and MIMO
I have try so many time about this with SONOS engineer, But not succes.
I can not find the SONOS in ORBI router from yesterday,reboot router and SONOS no use. Sonos can not connect to RBR20.
