rbachone
Sep 29, 2020Aspirant
sonos play 5 gen 2 will not connect to orbi
My Equipment: Spectrum Cable (400Mb/20Mb) Arris SB8200 DOCSIS 3.1, Orbi RBR40 running as router firmware V2.5.1.22, w/3 x RBS50 Netgear prosafe 16 port switch my issue after spending 3 days with SON...
Mstrbig
Sep 29, 2020Master
rbachone wrote:
I have tried plugging these in directly to the ORBI also tried connecting to the switch I can connect 1 but not the second one
I'm not too familiar with your SONOS setup, but is there a way to indivisually reset the speakers? It souns like stored settings are pre=venting you from setting them up, otherwise they should connect wired.
Also, do you have any firewall settings, circle or armor enabled, static IP settings, etc. on the Orbi?
rbachone
yes each speaker was reset individually as well as the app being reset I have turned off all firewall to get this done
- MstrbigSep 29, 2020Master
I found this searching the forum:
https://community.netgear.com/t5/Orbi/Sonos-can-t-connect-to-Orbi/m-p/1769478#M64789
- rbachoneSep 29, 2020Aspirant
yup I found that as well before I posted because none of the existing "fixes" did anything for my issue
