Jason2112
Jan 14, 2019Aspirant
Sony HTS7 subwoofer distorting
I’ve noticed my Sony subwoofer loosing signal and distorting in and out. I’m wondering if the orbi is causing the issue and how to fix it. Any suggestions.? My old router was in the same location and no issues there.
1 Reply
What FW is currently loaded?
Where is the device connected too? The base router or satellite? You might turn off any satellites and just have the device connect to the base router and see if the problem continues.What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.Distance between the device and the router or satellite?
Any Wifi Neighbors near by? If so, how many?Try disabling the following and see:
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
I would contact the Mfr for additional help and information regarding there product as well.
