Anjadekar
Nov 04, 2019Tutor
Sony ST-HT5000 soundbar's connection with subwoofer impacted by Orbi backhaul
I recently bought the Sony HT-ST5000 soundbar, which is quite a beast, with much excitement. Unfortunately, I have not been able to enjoy it to its optimum as it refuses to play nice with my home WiF...
Nov 04, 2019Guru - Experienced User
How close are these speaker systems to the Orbi RBR and RBS? Disstance and far appart will be a start.
(in my case the 5.2GHz Channel 3 worked best). Is this seen on the speakers UI? There is actually no channel 3 on the 5Ghz spectrum. There is 36 thru 48 and 149 thr 165 which is only used by Orbi and not configurable for anyone.
What 5Ghz channels do your speaker systems support? Any chance they have DFS support? Channels 100 thru 144? IF not, then set Orbi for say channel 48 and Speaker system to 36.
Might also try turning down the power output of the 5Ghz freqency on the RBR to see if this helps any. Under Advanced Tab/Advanced Settings/Wireless Settings
ekhalil
Nov 04, 2019Master
- Please disable Daisy Chain in Orbi. This will make the Satellite not to -unnecessarly- broadcast the wireless backhaul signal. Only the Router needs to broadcast this channel, which will reduce the interference on the Soundbar.
- If point 1 does not help, then you can try to change the backhaul channel to 108 (5.5 GHz) as follows:
- Enable telnet by going to orbilogin.com/debug.htm and telnet to Orbi router (default 192.168.1.1)
- Enter the following telent commands:
config set wla_2nd_hidden_channel=108
config commit
- Reboot the Router
- Please note that Orbi will automatically change to another channel if it detects interference on the backhaul channel. So please keep an eye on the backhaul channel after the above change.
