Anjadekar
Nov 04, 2019Tutor
Sony ST-HT5000 soundbar's connection with subwoofer impacted by Orbi backhaul
I recently bought the Sony HT-ST5000 soundbar, which is quite a beast, with much excitement. Unfortunately, I have not been able to enjoy it to its optimum as it refuses to play nice with my home WiF...
Anjadekar
Nov 04, 2019Tutor
Thanks for your reply FURRYe38. Here are the answers to your questions.
How close are these speaker systems to the Orbi RBR and RBS?
The speaker are abour 15-20 feet from the RBR and the RBS is on another floor.
(in my case the 5.2GHz Channel 3 worked best). Is this seen on the speakers UI?
Yes, the UI for the soundbar offers the options to connect on RF channels 1, 2 or 3 on either of the two RF bands, 5.2GHz or 5.8GHz (so, 6 options in total). The channel numbers confused me too and so I have included a screenshot for you to take a look.
Might also try turning down the power output of the 5Ghz freqency on the RBR to see if this helps
Is there a particular value that you suggest? Would doing so adversely impact the performance of the WiFi network?
Nov 04, 2019Guru - Experienced User
Might see if you can get more distance between the speaker system and RBR. If possible.
Ok so there channel naming convention is kind of non standard and are proprietary to there product. Kind of makes it hard.
Try lowering to 50% and test and see if this changes anything with the speaker system. Then up it to 75% and see.
