Anjadekar
Nov 04, 2019Tutor
Sony ST-HT5000 soundbar's connection with subwoofer impacted by Orbi backhaul
I recently bought the Sony HT-ST5000 soundbar, which is quite a beast, with much excitement. Unfortunately, I have not been able to enjoy it to its optimum as it refuses to play nice with my home WiF...
Anjadekar
Nov 17, 2019Tutor
Unfortunately I continued to experience disturbance on the subwoofer and so have had to replace the Orbi with my older NETGEAR R6400 router for now. This resolves the issue as the R6400, unlike the Orbi, operates only on the lower or upper end (as specified) of the 5GHz spectrum and so I can isolate the portion not used for the soundbar.
- FURRYe38Nov 18, 2019Guru - Experienced User
Ya sounds like the speaker system doesn't allow for much more channels to pick from. And using the same or upper frequencies as the Orbi wifi back haul which can't be disabled.
- RoyHobbsFeb 28, 2020Aspirant
Was anybody able to get the Orbi and the HT-ST5000 to play nice? I tried all the steps listed above and every combination of channels/frequencies on my Orbi and the soundbar with no luck
