CrimpOn
Jul 05, 2017Guru - Experienced User
Sort Attached Devices?
Is it possible to sort the list of attached devices, for example by IP address?
I have looked in the User Manual and have not found a way.
Thanks
- DarrenMSr. NETGEAR Moderator
Hello CrimpOn
No way to do that at this time its a great suggestion for a feature request.
DarrenM
Thanks for confirming. Netgear Genie on my R7000 does this, so I (naively) assumed that the Orbi would as well. (Why write different web code for routers? Why remove features from a router web interface?)
Thanks
