pbarham
May 09, 2020Apprentice
Spanning Tree problem with Orbi RBR50
I have been having network problems with my Orbi system for a few months now.. The symptoms are similar to issues others have reported, where satellites and other devices gradually disappear from th...
Jul 06, 2020Guru - Experienced User
Maybe only with with this one particular brand as well. Maybe there seems to be a incompatibility issue this with mfr. Try a different mfr or try a ethernet to USB C only adapter and leave off the USB ports. I have a couple of ethernet adapters and they work fine with my mac book pro. No USB ports though.
schumaku
Well possible various "brands" and "no-names" are soldering or OEM labeling such USB-C hubs with Ethernet ports based on some chip vendor sample PCB design, and deploying some basic firmware (there is on most of these devices!).
To keep it simple: An Ethernet adapter without an active controller (the USB-C host) can keep the link up (why ever, e.g. listening for WoL magic packet, ...) but under all circumstances it does not have to cause havoc on the network - regardless if this is STP (we have no proof, right?), reflecting traffic like broadcast, multicast (to much can lead to a port shutdown, too). If it does ... suspect trash.
Would be interesting to capture the data on that link. But that's a job for the vendors of these devices.
- mitsuhikoJul 06, 2020Tutor
For what it's worth it seems like an ANKER ethernet adapter connected to a powered USB-C hub seems to show the same behavior. That said, I'm not sure if it's a real ANKER adapter or actually a fake (bought it on amazon a while back).
- FURRYe38Jul 06, 2020Guru - Experienced User
Something to present the Mfrs of those devices. They should check this out.
Looking a bit more it seems like the most likely explanation is that the hubs send PAUSE flow control frames. People have reported issues with devices doing this before: http://jeffq.com/blog/the-ethernet-pause-frame/
If that's the case, then the issue is most likely at least in part with the Orbi.
Something that you can file a support ticket about and see. NG would have too look in to that. Again, the mfr of these devices should also review this as well. Possible that there maybe some standards that Orbi doesn't support or something that the mfr of these devices is doing that Orbi doesn't understand or support as well. With all the various mfrs of these devices, there bound to be one or some with odd problems with wifi routers. :smileyfrustrated:
- schumakuJul 07, 2020Guru - Experienced User
mitsuhiko wrote:Looking a bit more it seems like the most likely explanation is that the hubs send PAUSE flow control frames. People have reported issues with devices doing this before: http://jeffq.com/blog/the-ethernet-pause-frame/
100% an issue - not just with Orbi, probably with much more Netgear devices from both the consumer and the pro business unit.
Christian_R consumer BU
YeZ for small buisness BU
On the Smart Managed Pro product line, the issue was seen (in a different context) in 2017 already - and subsequentially fixed -> https://community.netgear.com/t5/Smart-Plus-and-Smart-Pro-Managed/STP-Leak-using-Broadcast-packet-01-80-c2-00-00-1c/td-p/1230027/page/2
- mitsuhikoJul 07, 2020Tutor
In my network I have an Orbi + two Orbi satellites as well a few switches, one of which is a Netgear unmanaged 4 port switch (FS105v3).
- FURRYe38Jul 07, 2020Guru - Experienced User
I would change out the FS switch for a GS switch. The FS switch will be only 100Mpbs vs GS which is 1000Mbps.
What other mfr and model# switches do you have?
mitsuhiko wrote:In my network I have an Orbi + two Orbi satellites as well a few switches, one of which is a Netgear unmanaged 4 port switch (FS105v3).
Sorry the model number was wrong. It's actually a GS305.
In total I have two Netgear GS305 and two TP-LINK TL-SG10.
Thanks for clairifying.
https://www.tp-link.com/us/business-networking/unmanaged-switch/tl-sg105/
Hope the TP Links work if you have the RBS connected. These have green ethernet features.
- mitsuhikoJul 11, 2020TutorI’m observing the same behavior with a Dell WD19TB. Given how popular, expensive and well tested it is, I’m assuming this is unlikely not to be a problem with either my switches or Orbi.
- mdsteele47Sep 23, 2020Aspirant
We appear to be experiencing a very similar problem with a Philips 272P7VU monitor that has a USB-C hub with an Ethernet jack. Can't quite isolate what the behavior is with the monitor that is causing the dropouts, but it is similarly killing every wired connection in on the RBR50 (which has a network switch attached to it).
Has anyone found a fix for this within the Orbi? I appreciated the link explaining the Ethernet Pause Frame but that didn't seem to point to a fix.
- schumakuSep 23, 2020Guru - Experienced User
mdsteele47 wrote:... Philips 272P7VU monitor that has a USB-C hub with an Ethernet jack. ... with the monitor that is causing the dropouts, but it is similarly killing every wired connection in on the RBR50 (which has a network switch attached to it).
For the moment there is no other option but disconnecting these hubs in direct connection with the network switches (e.g. the built-in on Orbi). The problem is that the Ethernet Pause Frame is intended to remain on the singe physical link (e.g. Orbi <-> Switch, Switch <-> Computer) only. Why ever, Ethernet Pause Frame is by error (switch chip embedded firmware) forwarded to other physical link where it
canwill stop that next port(s).
mdsteele47 wrote:Has anyone found a fix for this within the Orbi?
Nothing we can do from the user side for now - except to wait for an Orbi firmware update which does include and updated switch firmware (hopefully loadable by the host) and/or direct "host" ports are handling the Ethernet Pause Frame appropriately.
- FURRYe38Sep 24, 2020Guru - Experienced User
Be sure to let NG support know what your experiencing. The more information you give them the more apt they will take a look at hopefully fix this for you.
Also, try the use of a external Gb switch in the mix as well. Non managed and non green ethernet is recommended.
mdsteele47 wrote:We appear to be experiencing a very similar problem with a Philips 272P7VU monitor that has a USB-C hub with an Ethernet jack. Can't quite isolate what the behavior is with the monitor that is causing the dropouts, but it is similarly killing every wired connection in on the RBR50 (which has a network switch attached to it).
- mdsteele47Sep 24, 2020Aspirant
I'm already using a non-managed, non-green switch as a part of the setup. The problem persists with that switch.
Dumb question... is there a way to send this feedback to NG? My 90-day support window with them is long past up and I can't seem to identify a way to just send them this information otherwise.
- FURRYe38Sep 25, 2020Guru - Experienced User
What is the mfr and model # of this switch your using?
Send feed back to forum moderators if you don't have access to official support channels here:
https://www.netgear.com/support/#
mdsteele47 wrote:I'm already using a non-managed, non-green switch as a part of the setup. The problem persists with that switch.
- mdsteele47Sep 25, 2020Aspirant
Current switch is a Tenga TEG1008D. I originally had the TPLink TL-SG108 with the same results.
And if you remove these switches and direct connect the RBS, do you see any continued problems?
Yes. (You and I have discussed this in this thread.)
I remember now. This was seen when you used that offending device with Orbi huh... :smileyfrustrated:
- RyanSpohnFeb 21, 2021Aspirant
Piling on here. I am experiencing the same issue with different Orbi hardware and USB hub. I have an Orbi CBR40, and have two different USB hubs with gigabit ethernet ports (OWC Thunderbolt 3 Dock, and VAVA USB C Hub). When I have an ethernet cable plugged into either or both of the hubs, I experience the same issue described here. After 15 mins or so, every device on the wired network looses connection, yet the wifi network is unaffected. Restarting the Orbi fixes the issue temporarily only. When I remove the USB hubs from the equation there is no problem with the wired network. This is incredibly frustrating. The behavior described by pbarham and also in the Pause Frame article match my experience.
I am running the latest firmware for the device V2.5.0.14_1.0.8. No previous firmware updates have improved or fixed this behavior.
Is there any update on a coming fix from Netgear to address this, or has anyone found a workaround?
- FURRYe38Feb 22, 2021Guru - Experienced User
Something to contact the Mfr of these USB hubs about. If these are the only devices that don't work with Orbi, then you'll need to find help and information from the Mfr of these devices or find something that works. I have used small USBC to Ethernet adapters and these work for Orbi. Hubs seems to be a different animal and cause problems for Orbi systems.
RyanSpohn wrote:Piling on here. I am experiencing the same issue with different Orbi hardware and USB hub. I have an Orbi CBR40, and have two different USB hubs with gigabit ethernet ports (OWC Thunderbolt 3 Dock, and VAVA USB C Hub). When I have an ethernet cable plugged into either or both of the hubs, I experience the same issue described here. After 15 mins or so, every device on the wired network looses connection, yet the wifi network is unaffected. Restarting the Orbi fixes the issue temporarily only. When I remove the USB hubs from the equation there is no problem with the wired network. This is incredibly frustrating. The behavior described by pbarham and also in the Pause Frame article match my experience.
