AkoreJepade
Nov 11, 2022Tutor
Spanning tree settings on RBR50
Where does one find the Spanning Tree setting on the RBR50 router?
CrimpOn
Nov 11, 2022Guru - Experienced User
I am not aware of any customer settings in the RBR50 for this feature:
AkoreJepade
Nov 11, 2022Tutor
So, does that mean that it is always on and cannot be shut off or that it is always off, and it cannot be turned on?
- FURRYe38Nov 11, 2022Guru - Experienced User
Why would that need to be changed? Are you having problems with your system?
- AkoreJepadeNov 11, 2022Tutor
- CrimpOnNov 11, 2022Guru - Experienced User
Thanks for that link. I remember seeing posts a couple of years ago reporting problems with Sonos speakers. I realize that my Sonos One has an Ethernet jack on it, but I have never connected it that way. (The discussion quickly went over my head.)
Actually, it means I have no idea. Most of the discussions I find on this topic are about managed switches.
The RBR50 has a pretty primitive 4-port Ethernet switch in it. (Doesn't support VLANs of any sort - port or tagged, for example.) That would lead to a suspicion that it does not support any managed features.
There was a discussion in 2020 regarding this issue and the RBR50:
https://community.netgear.com/t5/Orbi/Spanning-Tree-problem-with-Orbi-RBR50/m-p/1910466
My guess is that it would be fairly simple experiment:
- Connect two ports of an unmanaged swtich to two Orbi LAN ports
- Connect one port of the swtich to a computer
- Set up something to watch the Ethernet traffic (BitMeter, for example: https://bitmeter.software.informer.com/3.6/ or Wireshark in promiscuous mode)
- Open a command window and issue an ARP command.
- If the network quickly goes crazy with broadcast packets, then there is no spanning tree support in the switch module.)
Either way, I have never seen anything that the user can do to control it.
