toxteth
Jul 26, 2020Initiate
Speaker unmutes itself
I have a RBS40V speaker satellite that I'm using for wifi but not for the speaker. I've found that the speaker will randomly unmute itself and occasionally will broadcast a message saying "orbi voic...
Papichulo33
Oct 04, 2020Initiate
Having the same issue and was wondering if anyone has found a resolution. Any updates is appreciated and would really like to hear from Netgear.
Thanks.
Thanks.
- MstrbigOct 04, 2020Master
The permanent fix is to setup the Alexa and register it. Then you can go in and disable pretty much anything you want. Until then you will get the reminder as many times as the Orbi app bugs you about signing up for Armor.
