testuserguy
Sep 09, 2022Guide
Specify VPN VLAN Starting Point
I have two different VLANs: IoT and everything else. I also have a VPN setup with my Orbi router. I wanted to know if it is possible to dump a user connection from the VPN into the IoT VLAN only, and...
- Sep 09, 2022
testuserguy wrote:
I was setting up the VLAN via my TP-Link though. In either case, it sounds like I cannot specify which VLAN or subnet the Orbi VPN has access to, correct? If not, I will seek another product's solution.
My Orbi has the same VLAN option. The Help Screen describes VLAN entirely in the context of the Internet Service Provider.
And you are correct that the user has no method to assign OpenVPN connections to a VLAN or specific IP subnet.
testuserguy
Sep 09, 2022Guide
Hi All,
I do have the RBR750, and it does have a VLAN section which allegedly supports tagging, as seen below:
CrimpOn
Sep 09, 2022Guru - Experienced User
