JC55
Feb 19, 2019Aspirant
Spectrum does NOT support Orbi CBR40 like the box list
I purchased the bundled CBR40 cable modem/router with 2 RBS20 Satellites. Figured easy setup...Spectrum was listed on the box right after Xfinity. HOWEVER, Spectrum had to send a tech to "provision" ...
JC55
Feb 20, 2019Aspirant
Thanks for the insight. I updated the FW and moved both satellites to the same room as the CBR40. I'll move them to opposite ends of the house tomorrow. BTW: house is one story 3000 sf. Yes, 2 satellites may be overkill, but also want solid coverage in the backyard.
Even though I had to verbally tell Spectrum that I was ok if I didn't get the speed expected...I just did a speed test 110.68 download and 10.34 upload and 10Ping. Thanks again.
Feb 21, 2019Guru - Experienced User
Just make sure the placement and distance between base router and satellites starts at about 30 feet. Any closer and you could see wifi problems appear. I have a 5000sq ft home and just one satellite. 40 feet in between. Great overage inside and out.
Enjoy. :smileywink:
