kai00051
Jan 25, 2019Aspirant
Spectrum Mobile - S9+ wifi seeing network twice
My family has 2 ipads, 2 kindles, 2 S7's, 2 Nest Cams, Chamberlain garage door, 1 Roku TV and a Chromecast device - NONE of which have problems with my Orbi mesh network.
I just got an S9+ throug...
Jan 25, 2019Guru - Experienced User
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What WPA security modes are you using? Try WPA2 and AES only
MIMO, Daisy Chain, Fast Roaming, IPv6 and Un-check 20/40Mhz Coexistence to set 40Mhz only. Save settings and reboot the router and satellite(s). If MIMO is already disabled, try enabling it. You can revert all these changes if nothing helps.
Is IPv6 enabled on the phone, try to disable it and see.
Overall this will be a Samsung issue that they need to look into. There devices need to be tested to ensure they work on most MESH systems correctly. I seems to be an issue of how the Samsung device is handling and interacting with the Orbi MESH system and Smart Connect. If all other devices are working well with the Orbi, then Samsung needs to do some testing. They can also contact NG for engineering help if there seems to be compatibility issues between them. I have a S8, S7J and Galaxy Tab S2 and they all work on my Orbi system.
I just got an S9+ through Spectrum Mobile (up to date on software), and it cannot, CANNOT, stay on my Orbi mesh network (router and one satellite - both up to date on firmware). The 2.4 and 5 are named the same (by design) and the phone just bounces back and forth all day long between the 2.4 to 5, and in the meanwhile uses data when struggling with wifi.
My other phones don't even see 2 networks, just one. The S9+ displays the network twice.
Specturm is no help. Samsung is no help. Netgear was no help.
What is a guy to do? So frustrating.
FWIW, my dad came over with his Spectrum Mobile LG phone and he could not stay connected to my wifi. Although he didn't see my network SSID 2x like I do, his continually connected and disconnected from my network.
This appears to be an issue with Spectrum Mobile and mesh networks. I'm not going to lay blame on Orbi yet as 19 other devices in my house, connect just fine. The only ones having issues ar the Spectrum Mobil S9+ and Spectrum Mobile LG.
- kai00051Jan 25, 2019Aspirant
Orbi FW: v2.2.1.210
Modem: Arris TM1602A
Router Setup:
Set up standard out of the box
Operation Mode: Router
WPA2-PSK {AES}
2.4ghz: auto
5ghz: 48
Yes, wifi neighbors nearby, never been a problem - again, 19 devices on my network with no problem, and 2 Spectrum Mobile phones struggle (S9+ and LG).- FURRYe38Jan 25, 2019Guru - Experienced User
Ok was checking the modem configuration and what you were using on the Orbi. You can try those other suggestions to see if they help with the Samsung devices. This can be something else you can give to Samsung as well to let them know what you have tried.
kai00051 wrote:
Orbi FW: v2.2.1.210
Router Setup:
WPA2-PSK {AES}
2.4ghz: auto
5ghz: 48
Yes, wifi neighbors nearby, never been a problem - again, 19 devices on my network with no problem, and 2 Spectrum Mobile phones struggle (S9+ and LG).- kai00051Jan 25, 2019Aspirant
I guess I'm just annoyed/shocked that I need to make specific router changes (possibly) to accomodate a Spectrum phone, while all other devices work perfectly fine.
