realien
Jul 10, 2020Tutor
Speed expections over 5g with a 700 mbit pipe
What speed expecations should I have from the main RBK50 to a mac over 5g ?
Testing directly with the Orbi / Advanced / Speed test I see 761 MBps from the Comcast X1 modem using a CAT5e cable
When testing over speedtest from my mac over wifi I see 200Mbs - 300Mbps over 5ghz depending on its mood.
I'm about 15 feet from the RBK50. with no walls or obstructions.
I would have hoped to see 400mbits + pretty consistently but I've never seen it.
Depending on the design of the mac and what it supports. Most speeds you'll ever see on 5Ghz AC is around 300-500max. Depending on HW support and it's design.
Here what I get with my Mac Book Pro 2018 sitting in my living room several feet away from the RBS or RBR: v16
- realienTutor
interesting as the mac is supposed to be capable of 800mbs on 5g.
wfi scanner, shows a Signal of -63db, -77dbm noise, SNR14 and data rate of 866, TX of 65.
I'm going to have to go google of those signal levels and noise levels are good. I believe 63dbmsignal and over 70dbm noise is good.
realien wrote:interesting as the mac is supposed to be capable of 800mbs on 5g.
The theoretical maximum rate over 5G and AC is 866 Mbps: https://kb.netgear.com/31211/At-what-speed-and-bandwidth-can-my-Orbi-system-transmit-data . However, the transmission rate you actually experience is greatly reduced due to communication overhead, encryption, environmental factors, etc.
