realien
Jul 10, 2020Tutor
Speed expections over 5g with a 700 mbit pipe
What speed expecations should I have from the main RBK50 to a mac over 5g ? Testing directly with the Orbi / Advanced / Speed test I see 761 MBps from the Comcast X1 modem using a CAT5e cable ...
Jul 13, 2020Guru - Experienced User
realien
Jul 13, 2020Tutor
Thanks
Network utiliity reports 54mbit/s but I think that's a bug, wifi diagnostic show 1300 MBps Tx rate
My network diags attached since I can't insert images for some reason...
- FURRYe38Jul 13, 2020Guru - Experienced User
Ya I get between 65-292Mbps on OSX 10.14.6 for some reason. :smileyfrustrated: Though I'm sitting at a distance from the RBR or RBS.
